Hi All,
We are evaluating Squidex and so far the entire team has been very impressed with its architecture and ease of use. We are using Squidex.ClientLibrary #6.8.0 and have below questions.
- Do the SquidexClientManager cache the required token to call Squidex API and refresh it automatically? Or, should we implement the caching at our end ?
- Creating AssetClient and ContentClient costly operation ? Meaning should we try to store an instance of it in memory and re-use it ? Or, it is okay to create them as and when needed ? Which approach do you recommend ?
- For a schema with JSON file type, what should be the underlying C# property type ? Can it be string ?
thank you very much for your nice words. About your questions:
- SquidexClientManager handles it, but you can override it, by writinga custom Authenticator. This is the default: https://github.com/Squidex/squidex-samples/blob/master/csharp/Squidex.ClientLibrary/Squidex.ClientLibrary/Configuration/CachingAuthenticator.cs
- The creation is not costly, but it creates a HttpClient for each client and then it needs to resolve host names, establish a SSL connection and all this stuff which is very expensive. Reusing the clients in my integration tests improved the performance by factor 3.
- It needs to be compatible with JSON.NET. You can write a custom serializer that serializes to string. Otherwise I either recommend
JToken or a class structure that represents your json structure.
Thanks for your response Sebastian.
