We are using Squidex.ClientLibrary version 6.8.0 and to add an asset, we’re using the “PostAssetAsync” method of IAssetsClient. When we try to upload a file, we receive an error message “Error while copying content to a stream.” . When we tried the same file via UI, we see “Asset is too big” message. So, we are assuming that the API is unable to handle the error and throws it back as an exception.
Is that the case ? Can you confirm ? Also, what is your recommendation to handle such errors ? Is there a specific exception type that we can catch and act upon ?
Below is the stack trace. Let me know if you need any more details.
at System.Net.Http.HttpContent.<CopyToAsyncCore>d__49.MoveNext()
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable.ConfiguredTaskAwaiter.GetResult()
at System.Net.Http.MultipartContent.<SerializeToStreamAsyncCore>d__18.MoveNext()
at System.Runtime.CompilerServices.ConfiguredValueTaskAwaitable.ConfiguredValueTaskAwaiter.GetResult()
at System.Net.Http.HttpConnection.<SendRequestContentAsync>d__58.MoveNext()
at System.Net.Http.HttpConnection.<SendAsyncCore>d__53.MoveNext()
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
at System.Net.Http.HttpConnectionPool.<SendWithNtConnectionAuthAsync>d__48.MoveNext()
at System.Net.Http.HttpConnectionPool.<SendWithRetryAsync>d__47.MoveNext()
at System.Net.Http.RedirectHandler.<SendAsync>d__4.MoveNext()
at System.Net.Http.DiagnosticsHandler.<SendAsync>d__2.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
at Squidex.ClientLibrary.Utils.AuthenticatingHttpMessageHandler.<SendAsync>d__2.MoveNext()
at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__71.MoveNext()
at Squidex.ClientLibrary.Management.AssetsClient.<PostAssetAsync>d__21.MoveNext()
at XPS.Gateways.Squidex.SquidexGateway.<AddAssetAsync>d__3.MoveNext() in C:\Projects\Stash\poc\XPS.Gateways\Squidex\SquidexGateway.cs:line 37
