[Squidex CLI] sq indexes
When using sq indexes --help, it shows the following.
Manage schemas.
Usage: Squidex.CLI.dll indexes [command]
Commands:
create Create a new index.
drop Create a new index.
list List all schemas.`
When running sq --help, it also has confusing documentation listed below as it shows both indexes and schemas with the same description.
Usage: Squidex.CLI.dll [command]
Commands:
ai Uses AI commands.
indexes Manage schemas.
schemas Manage schemas.
It should be “Manage Indexes” and “List all indexes” instead?
Simply run the commands such as
  • sq indexes --help;
  • sq --help.
  • Squidex CLI
Version: Squidex CLI v13.7.0.0, API Compatibility >= 4.X
Thank you very much. Will be fixed. You can also create a PR: GitHub - Squidex/squidex-samples: Samples for Squidex
Thank you, Sebastian.
I have created a PR to fix this issue: Corrected "schemas" to "indexes" under App_Indexes. by goh-chunlin · Pull Request #89 · Squidex/squidex-samples · GitHub
Thanks again for your prompt response!
