I have a schema like that:
I dont know why the api doesnt return Author property?
How can I get Author property from the API?
Usually the OpenAPI output is a cached for a few minutes. If you tell me where you have hosted your instance and the app name I can also have a look.
Its there now, I see the field.
Okay, It’s link, this is a name confusing issue…
