Squidex 4 - 500.30 Error
Windows 2016
IIS 10
DotNet Core 3.0 Installed
Hi
I downloaded the new Squidex version. however, this version does not work within the IIS. Since I always get a 500.30 error message. After closing the message, it is the used port 5001.
Therefore, I have set a new port in the appsettings for the Kestrel.
"Kestrel": {
    "EndPoints": {
        "Http": {
            "Url": "http://localhost:5999"
Now I can go to the cmd dotnet ./Squidex.dll and run in Chrome with this port. However, IIS still does not work with my domain. I still get the same message.
Does Squidex 4 have to be operated as a reverse proxy? Or is there a trick? Other dotnet core 3 applications (mine) work without any problems.
i also had the same problems on another server.
Greetings Andreas
Are you sure that port 5001 is available?
the first server no.
No at the first server. There is still a GPS portal with the Post 5001 running.
That’s why the setting of the port 5999, this is free.
But the second server on which I tested this is the port 5000 and 5001 Free.
You can run it without kestrel and see what happens. Just a dotnet Squidex.dll should work.
that is, only one installation per server can be run? I’ll test tomorrow on a server where there is no installation.
I think when you run ASP.NET Core with the in-process model it should not be a problem. But IIS is not so user friendly when you get startup errors. Therefore my recommendation is to test it without IIS first to see if the configuration is correct. When I google for 500.30 I get results about startup errors.
Just to document it:
So with dotnet ./Squidex.dll everything works fine. not within the IIS.
I will rehearse a bit and see if I can find a solution.
Hi
Everything works now.
Tonight, backed up all Squidex apps and databases. All installations deleted and now have only one installation with version 4.
Since then everything works. :slight_smile:
Greetings Andreas
