- [X] Documentation issue or request
I am currently using the following GraphQL query to get all my data sorted by the date the entity was created:
query { queryMediaPageContents (orderby: "created") { id flatData { title } } }
The problem is that I get it sorted in descending order while I need it in ascending order, but this option isn’t covered in API documentation:
Is there any way to specify sorting order?
Received data is sorted in specified order.
- [X] Cloud version
- [X] Chrome (desktop)
