[SOLVED] Workflow doesn't save schema option
I have a workflow where I’d like setting schemas. When I set schemas and save the workflow, the schemas option are not saved.
The bug is also on cloud.
  • [ X] Bug report
  • [ X] Self hosted with docker
  • [ X] Cloud version
Version: [5.8.0]
  • [X ] Chrome (desktop)
Thx, I will have a look.
I have fixed it. It is only one small change in the WorkflowDto.cs file: https://github.com/Squidex/squidex/commit/0f0f93eef9e4b56d5c0d562a62fe53908a372250#diff-e7d56ced69c2e88d72cdf1c05c0c8abe6f026d953bbbd4013e1d0b14f2192d83
In case you want to backport it.
thanks a lot.
Federica
