[SOLVED] Using $search not working for array type
my structure:
data {
	title {
		iv: 'foo'
	array {
		iv [
				title: 'bar'
If i call:
…schema?$search=bar
return nothing.
It doen’t work or i’m doing something wrong?
Please use markdown and spend a little bit time for formatting your code and posts.
Actually it is a bug or missing feature, I can fix it until tomorrow.
Hi, I have fixed and deployed it.
You have to save the items again so that the full text index gets updated. But you have to make at least a small change like adding a whitespace or so.
Thanks Sebastian, works fine
