[SOLVED] Upgrade from 7.9.0 to 7.12.0
Basically, I just changed the version to the last one (7.12.0) and squidex does not start at all.
18 Jan 2024 22:41:37.097
 at Squidex.Program.Main(String[] args) in /src/src/Squidex/Program.cs:line 17
18 Jan 2024 22:41:37.096
 at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
 at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
18 Jan 2024 22:41:37.095
18 Jan 2024 22:41:37.094
 at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
18 Jan 2024 22:41:37.093
 at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService[T](IServiceProvider provider)
18 Jan 2024 22:41:37.092
 at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService(IServiceProvider provider, Type serviceType)
18 Jan 2024 22:41:37.091
 at Microsoft.Extensions.DependencyInjection.ServiceProvider.GetService(Type serviceType)
 at Microsoft.Extensions.DependencyInjection.ServiceProvider.GetService(ServiceIdentifier serviceIdentifier, ServiceProviderEngineScope serviceProviderEngineScope)
18 Jan 2024 22:41:37.090
 at System.Collections.Concurrent.ConcurrentDictionary`2.GetOrAdd(TKey key, Func`2 valueFactory)
18 Jan 2024 22:41:37.089
 at Microsoft.Extensions.DependencyInjection.ServiceProvider.CreateServiceAccessor(ServiceIdentifier serviceIdentifier)
18 Jan 2024 22:41:37.088
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.Resolve(ServiceCallSite callSite, ServiceProviderEngineScope scope)
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSite(ServiceCallSite callSite, TArgument argument)
18 Jan 2024 22:41:37.087
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitRootCache(ServiceCallSite callSite, RuntimeResolverContext context)
18 Jan 2024 22:41:37.086
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSiteMain(ServiceCallSite callSite, TArgument argument)
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitIEnumerable(IEnumerableCallSite enumerableCallSite, RuntimeResolverContext context)
18 Jan 2024 22:41:37.085
18 Jan 2024 22:41:37.084
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitConstructor(ConstructorCallSite constructorCallSite, RuntimeResolverContext context)
18 Jan 2024 22:41:37.083
18 Jan 2024 22:41:37.082
18 Jan 2024 22:41:37.081
 at Microsoft.Extensions.DependencyInjection.DependencyInjectionExtensions.InterfaceRegistrator`1.<>c.<.ctor>b__3_1(IServiceProvider c)
18 Jan 2024 22:41:37.080
 at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngineScope.GetService(Type serviceType)
18 Jan 2024 22:41:37.079
18 Jan 2024 22:41:37.078
18 Jan 2024 22:41:37.077
18 Jan 2024 22:41:37.076
18 Jan 2024 22:41:37.075
18 Jan 2024 22:41:37.074
18 Jan 2024 22:41:37.073
 at Microsoft.Extensions.DependencyInjection.DependencyInjectionExtensions.InterfaceRegistrator`1.<>c.<As>b__9_0(IServiceProvider c)
18 Jan 2024 22:41:37.072
18 Jan 2024 22:41:37.064
18 Jan 2024 22:41:37.063
18 Jan 2024 22:41:37.058
18 Jan 2024 22:41:37.057
18 Jan 2024 22:41:37.053
18 Jan 2024 22:41:37.051
18 Jan 2024 22:41:37.050
18 Jan 2024 22:41:37.049
 at System.Array.InternalSetValue(Object value, IntPtr flattenedIndex)
18 Jan 2024 22:41:37.048
 Unhandled exception. System.InvalidCastException: Object cannot be stored in an array of this type.
this log is tereble but it seems as it is print by squidex line by line. We have setup seq log for this app.
If i remember correctly it wont work even with 7.10.0 (by them i just revert version back).
That one would be tricky as it is sort of “production” app
Version: 7.9.0 (mostly likely something after 7.90)
Please remove the settings APPS__DELETEPERMANT for now. This is the culprit.
Nice it works now this can be closed as per squidex github seems it will be fixed in next release :wink:
Yes, I will make a release soon.
