- [ x Used code blocks with ``` to format my code examples like JSON or logs properly.
Previously working queries seem to have started failing today, with error messages regarding unknown types for components.
The query works as it did previously.
Try to run a grahql query which uses embedded components, like this:
queryDocumentContents {
id
flatData {
slug
components {
__typename
...CalloutComponent
fragment CalloutComponent on CalloutComponent {
text
Where CalloutComponent is defined as a component:
An error is reported:
"Unknown type - CalloutComponent"
I’m seeing this for multiple component types.
- [x] Cloud version
