[SOLVED] Unable to import contents with json due to camelcase differences
  • [x] Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
  • [x] Bug report
I want to export and import contents form one squidex environment to the other, using the cli. The content is correctly exported however, as soon as I import the content I get validation errors.
For instance:
.\sq.exe content import text text.json --format=JSON
   "message":"Validation error",
   "traceId":"00-dc8069c6ffcfc645b6a44f5de785e05b-43d2116d105d0545-00",
   "type":"https://tools.ietf.org/html/rfc7231#section-6.5.1",
   "details":[
      "anchorLinkText.fr-BE: Field is required.",
      "anchorLinkText.nl-BE: Field is required.",
      "showOnPhone.fr-BE: Field is required.",
      "showOnPhone.nl-BE: Field is required.",
      "richText.fr-BE: Field is required.",
      "richText.nl-BE: Field is required.",
      "cMSTitle.iv: Field is required.",
      "anchorLinkText: Not a known field.",
      "showOnPhone: Not a known field.",
      "richText: Not a known field.",
      "cmsTitle: Not a known field."
   "statusCode":400
I noticed that it is a problem with the capitalization. It expects RichText instead of richText, if I update the capitalization, the import works fine.
I would expect that the export can be used immediately for the import, without any alterations. Or is there an argument that fixes the capitalization?
  • [ ] Self hosted with docker
  • [x] Cloud version
  • [x] Chrome (desktop)
Please use code blocks to format errors and json like above. It is super hard to read like that.
I have solved it. A new version of the CLI is in the pipeline.
