We are experiencing an issue when selecting items from a list in the CMS. When the selection popup appears, I have a list of entities that I can select. However should my mouse pass over the green image from the updated column, the popup disappears and I cannot then save the schema. I have to reload the schema and try not to let my mouse pointer his the green circle when trying to select from a list - which is quite a common task being carried out by the content managers.
Can you take a look please, as its getting really frustrating for the team
Thanks
