- [x] Bug report
I have:
A Default type component (named country), with a Components (array of components) field referenced (named score).
When syncing out/in, if there is at least one score in the field, I get this error:
failed: Validation error: indicators.iv: Invalid component. Cannot find schema.
The countries that have an empty scores field sync correctly
Should import whether there are values in the scores field or not
Minimal simplified schemas:
COUNTRY
"schema": {
"fields": [
"name": "scores",
"partitioning": "invariant",
"properties": {
"fieldType": "Components",
"schemaIds": [
"score"
"isPublished": true
"name": "country",
"isSingleton": false,
"schemaType": "Default"
SCORE
"schema": {
"fields": [
"name": "score",
"schemaType": "Component"
- [x] Cloud version
Version: [CLI 9.6]
