- [x] Bug report
This is a bug related to Node.js making a graphql request for content and setting a take value (>60). The response header includes the surrogate key field which includes the ids of the requested graphql content. The value of this header can easily bloat the response headers to greater than 8kb, the maximum default header size supported in Node.js, resulting in a system header overflow error.
I do not know if this is a feature or a bug depending on the scope and purpose of this header in relation to graphql. This can be avoided in Node by using pagination properly and not requesting so many records.
I wanted to make a record for posterity so other Node developers know about the header overflow issue for requesting too much information.
Make a request to content that returns a response header with ~60 surrogate keys (content ids) and check the size of the response header. It should be greater than 8kb.
I was able to submit a graphql query in postman and inspect the response headers and size as more data was fetched in parody with node until node crashed.
- [x] Cloud version
Version: [Latest Cloud Version]
- [ ] Chrome (desktop)
