- [X] Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
The logs don’t show anything out of the ordinary.
- [X] Regression (a behavior that stopped working in a new release)
Previously when using version 5.7.1 I set the URL to always be HTTP. My current environment is such that I cannot use SSL. The login popup always followed the protocol I specified for the instance URL. When upgrading to 5.8.0, the behaviour changed to what is happening now which is the login popup always uses HTTPS. Which always results in an error since I don’t have an SSL certification at all.
The login popup should use HTTP when the URL specifies only HTTP as the protocol.
- [X] Self hosted with docker
Version: 5.8.0
- [X] Chrome (desktop)
- [X] Firefox
Environment:
- URLS__BASEURL=http://${SQUIDEX_DOMAIN}:5000
- URLS__ENFORCEHTTPS=false
- EVENTSTORE__TYPE=MongoDB
- EVENTSTORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- STORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- IDENTITY__GITHUBSECRET=${SQUIDEX_GITHUBSECRET}
- ASPNETCORE_URLS=http://*:5000
