[ ] Regression (a behavior that topped working in a new release)
[ X] Bug report
[ ] Performance issue
When running squidex locally and the UI for it, I go to log in at localhost:5000, I use the Google authentication method with the account I use every time, I click login then it just redirects me back to the login page. No errors of any kind that are visible to me. This has happened before but went away for awhile, now the issue is back so I can’t access the UI.
Should be able to login and get taken to my apps like normal.
- [ ] Self hosted with version docker
- [X ] Self hosted with other version
- [X ] Chrome (desktop)
STACK TRACE:
“logLevel”: “Information”,
“elapsedRequestMs”: 265,
“app”: {
“name”: “Squidex”,
“version”: “1.0.0.0”,
“sessionId”: “8d09b6ef-eddd-457e-861a-a9e5655bcbed”
“web”: {
“requestId”: “dff05a37-ba3b-4d87-94ad-e2cfe6439bdc”,
“requestPath”: “/identity-server/signin-google”,
“requestMethod”: “GET”
“timestamp”: “2018-08-17T14:06:45.1847098Z”
“elapsedRequestMs”: 3,
“app”: {
“name”: “Squidex”,
“web”: {
“requestId”: “3e5ba72c-890b-497b-b4ba-ac133f635407”,
“requestPath”: “/identity-server/account/external-callback”,
“timestamp”: “2018-08-17T14:06:45.1946531Z”
“message”: “Invoking IdentityServer endpoint: IdentityServer4.Endpoints.AuthorizeCallbackEndpoint for /connect/authorize/callback”,
“endpointType”: “IdentityServer4.Endpoints.AuthorizeCallbackEndpoint”,
“url”: “/connect/authorize/callback”,
“app”: {
“name”: “Squidex”,
“web”: {
“requestId”: “c8de9229-eaa3-4d48-b342-a85b077f9771”,
“requestPath”: “/connect/authorize/callback”,
“timestamp”: “2018-08-17T14:06:45.2013118Z”,
“category”: “IdentityServer4.Hosting.IdentityServerMiddleware”
“message”: “ValidatedAuthorizeRequest\r\n{\r\n “ClientId”: “squidex-frontend”,\r\n “ClientName”: “squidex-frontend”,\r\n “RedirectUri”: “http://localhost:5000/client-callback-popup”,\r\n “AllowedRedirectUris”: [\r\n “http://localhost:5000/login;”,\r\n “http://localhost:5000/client-callback-silent”,\r\n “http://localhost:5000/client-callback-popup”\r\n ],\r\n “SubjectId”: “anonymous”,\r\n “ResponseType”: “id_token token”,\r\n “ResponseMode”: “fragment”,\r\n “GrantType”: “implicit”,\r\n “RequestedScopes”: “squidex-api openid profile email squidex-profile role”,\r\n “State”: “167f7f1eaa2742208643c6a092fd0259”,\r\n “Nonce”: “f47e2b790fd54110bff54a44ac752df1”,\r\n “DisplayMode”: “popup”,\r\n “Raw”: {\r\n “client_id”: “squidex-frontend”,\r\n “redirect_uri”: “http://localhost:5000/client-callback-popup”,\r\n “response_type”: “id_token token”,\r\n “scope”: “squidex-api openid profile email squidex-profile role”,\r\n “state”: “167f7f1eaa2742208643c6a092fd0259”,\r\n “nonce”: “f47e2b790fd54110bff54a44ac752df1”,\r\n “display”: “popup”\r\n }\r\n}”,
“validationDetails”: “{\r\n “ClientId”: “squidex-frontend”,\r\n “ClientName”: “squidex-frontend”,\r\n “RedirectUri”: “http://localhost:5000/client-callback-popup”,\r\n “AllowedRedirectUris”: [\r\n “http://localhost:5000/login;”,\r\n “http://localhost:5000/client-callback-silent”,\r\n “http://localhost:5000/client-callback-popup”\r\n ],\r\n “SubjectId”: “anonymous”,\r\n “ResponseType”: “id_token token”,\r\n “ResponseMode”: “fragment”,\r\n “GrantType”: “implicit”,\r\n “RequestedScopes”: “squidex-api openid profile email squidex-profile role”,\r\n “State”: “167f7f1eaa2742208643c6a092fd0259”,\r\n “Nonce”: “f47e2b790fd54110bff54a44ac752df1”,\r\n “DisplayMode”: “popup”,\r\n “Raw”: {\r\n “client_id”: “squidex-frontend”,\r\n “redirect_uri”: “http://localhost:5000/client-callback-popup”,\r\n “response_type”: “id_token token”,\r\n “scope”: “squidex-api openid profile email squidex-profile role”,\r\n “state”: “167f7f1eaa2742208643c6a092fd0259”,\r\n “nonce”: “f47e2b790fd54110bff54a44ac752df1”,\r\n “display”: “popup”\r\n }\r\n}”,
“app”: {
“name”: “Squidex”,
“web”: {
“timestamp”: “2018-08-17T14:06:45.2067536Z”,
“category”: “IdentityServer4.Endpoints.AuthorizeCallbackEndpoint”
“message”: “Showing login: User is not authenticated”,
“app”: {
“name”: “Squidex”,
“web”: {
“timestamp”: “2018-08-17T14:06:45.2122242Z”,
“category”: “IdentityServer4.ResponseHandling.AuthorizeInteractionResponseGenerator”
“elapsedRequestMs”: 16,
“app”: {
“name”: “Squidex”,
“web”: {
“requestPath”: “/identity-server/connect/authorize/callback”,
“timestamp”: “2018-08-17T14:06:45.2176662Z”
“elapsedRequestMs”: 1,
“app”: {
“name”: “Squidex”,
“web”: {
“requestId”: “f4f984f3-ae70-4dcf-9a03-7f8e8b7cd06e”,
“requestPath”: “/identity-server/account/login”,
“timestamp”: “2018-08-17T14:06:45.2269475Z”
