- [x] Bug report
We are using version 8.19.0 of the Squidex CLI.
We are running the command:
sq sync out packages/squidex/schema/gp2 -t rules
Which produces the following JSON:
"$schema": "./../__json/rule.json",
"isEnabled": true,
"name": "Entity updated",
"trigger": {
"triggerType": "ContentChanged",
"schemas": [
"schemaId": "users",
"condition": "event.type === 'Created' || event.type === 'Published' || event.type === 'Unpublished' || event.type === 'Updated' || event.type === 'Deleted'"
"handleAll": false
"action": {
"url": "https://api-dev.gp2.asap.science/webhook/squidex",
"method": "POST",
"sharedSecret": "a-very-secret-secret",
"actionType": "Webhook"
As part of the CI we would like to re-sync this with another Squidex using:
sq sync in packages/squidex/schema/gp2 -t rules
We get:
Rule 'Entity updated' creating... failed: Squidex.ClientLibrary.SquidexException: Squidex Request failed: {"message":"Validation error","traceId":"00-9e6ebf92da710eafe2943636bb27ec3c-b847ba1311343a0a-01","type":"https://tools.ietf.org/html/rfc7231#section-6.5.1","details":["action: Action is required."],"statusCode":400}
at Squidex.ClientLibrary.Utils.SquidexClientBase.EnsureResponseIsValidAsync(HttpResponseMessage response)
at Squidex.ClientLibrary.Utils.SquidexClientBase.RequestJsonAsync[T](HttpMethod method, String path, HttpContent content, QueryContext context, CancellationToken ct)
at Squidex.CLI.Commands.Implementation.Sync.Rules.RulesSynchronizer.<>c__DisplayClass8_2.<<ImportAsync>b__6>d.MoveNext()
--- End of stack trace from previous location ---
at Squidex.CLI.Commands.Implementation.LogExtensions.DoSafeAsync(ILogger log, String process, Func`1 action).
App Name: p2-hub-dev and gp2-2028
- [x] Cloud version
Version: NA
- [ ] Chrome (desktop)
