- Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
- Bug report
- Performance issue
The separator for the login methods shows even when it shouldn’t. Depending on what combination of login methods are enabled it’s showing even when it has no other method above it. Here are examples I gathered.
Only show the separator in between login methods
easiest example is:
- External auth: false
- Password auth: true
- Custom auth: false/true
- Self hosted with docker
- Self hosted with IIS
- Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
I will probably fix this soon myself. So I could make a PR for it.
