No content change rules are triggering
Content change rule needs to be triggered after publishing content
- Create a rule for content change and map it to a webhook.
- Create content.
- [X ] Cloud version
- [X ] Chrome (desktop)
Sorry for the bad communication, I am running a migration at the moment, which affects the rules.
But when it is completed, it will just continue with handling old events.
They should work properly now, can you verify that?
Now rules are triggering . However I am getting the below error in logs.
System.Threading.Tasks.TaskCanceledException: The operation was canceled.
—> System.IO.IOException: Unable to read data from the transport connection: Operation canceled.
—> System.Net.Sockets.SocketException (125): Operation canceled
— End of inner exception stack trace —
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token)
at System.Net.Security.SslStream.g__InternalFillBufferAsync|215_0[TReadAdapter](TReadAdapter adap, ValueTask1 task, Int32 min, Int32 initial) at System.Net.Security.SslStream.ReadAsyncInternal[TReadAdapter](TReadAdapter adapter, Memory1 buffer)
at System.Net.Http.HttpConnection.FillAsync()
at System.Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync(Boolean foldedHeadersAllowed)
at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithNtConnectionAuthAsync(HttpConnection connection, HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.FinishSendAsyncBuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts)
at Squidex.Extensions.Actions.HttpHelper.OneWayRequestAsync(HttpClient client, HttpRequestMessage request, String requestBody, CancellationToken ct) in /src/extensions/Squidex.Extensions/Actions/HttpHelper.cs:line 46
Action timed out.
Elapsed 00:00:02.0040000.
This means that for whatever reason it cannot establish a connection and has timed out after 2 seconds. Usually a problem with the endpoint.
