If i try to restore backup (±500MB) with some sample app (about 100k events mostly generate during import testing). I end up with out of memory exception when server have 2GB ram (same with local docker instance when I have set limit 2GB for WSL2) In both case it isn’t issue with 4+ GB ram for my test case. But I worry about scaling in future when I have bigger application. I also want to attach profiler and check what happen but i am not able to make squidex workly locally.
- [x] Performance issue
I expect restoring from backup is not limit by memory it is perfectly fine if take longer but should not fail with out of memory for any “reasonable” HW.
Non “minimal” backup with images & 100k+ evets.
- [x] Self hosted with docker
Version: 4.6
