- [ x ] Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
- [ x ] Bug report
Hi, I’m using Postman to get data from Squidex’s REST API. I just noticed that my request will get failed if my schema contains over 100 records. Please take a look at my screenshot below:
This university-reviews schema contains 109 records and it doesn’t work. I have some other schemas (over 100 records) that don’t work either.
Another schema, it’s websites. It has 40 records, and it works perfectly.
Should return data without Error: Parse Error: Header overflow
- [ x ] Self hosted with other version
- [ x ] Chrome (desktop)
