- [x] Bug report
When restoring previously created backups via the Restore Backup function the data shown in the “References” and “Referencing” content tabs is not properly restored.
The corresponding API calls (like the GraphQL referencingSCHEMA_NAMEContents operation) also just return an empty list.
The restored contents however still contain the IDs of the referenced contents and changing anything (like a field value) on the content that references another content fixes the problem.
Referenced and referencing content is correctly restored when restoring an App via the builtin Restore Backup function.
- Create a new App
- Add a new schema with the following configuration:
- Name: Address
- Fields:
- id (FieldType: String)
- Add a second schema:
- Name: Person
- Fields:
- addresses (FieldType: References)
- Add a few
Addresscontents (e.g. with theids1, 2, 3) - Create a new
Personcontent whoseaddressesfield is populated with references to the previously created addresses - Check if the data in the
Referencestab on the person shows up correctly - Check if the data in the
Referencingtab on the addresses show up correctly - Create a backup of the App
- Restore the previously created backup
- Check 6 & 7 again in the restored App (The data is now “missing”, changing anything on the person however fixes the problem)
- [x] Self hosted with kubernetes
Version: 7.7.0
- [x] Chrome (desktop)
The problem already existed in the previous version.
