The current version shows this in reference field schemas.field.references.query a believe there was select component with suggestion but I am not completely sure. But it definitely suggests schemes as the current version is prone to error.
edit: this is how its look for componet
Create app with 2 schemas and then in one add field reference and try to set schema (type).
- [x] Self hosted with docker
- [x] Cloud version
Version: 7.8.2
- [ ] Chrome (desktop)
- [x] Brave
