When I use quick nav to try find items in any schema, they are properly displayed in a dropdown, but when I click on any item, I am not getting navigated to it. When I click item or press enter, nothing happens, only the quick nav content gets replaced with [object Object].
I was told it started happening around two weeks ago.
I would expect to navigate to the item I clicked on.
- Search using the quick nav
- Click on any result in the dropdown
- [x] Cloud version
Version: 4.0.0.0
- [x] Chrome (desktop)
