- [x]
Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
- [x] Bug report
Managing the columns/fields that are visible on the list view of a schema has some bugs:
- you can’t reorder the fields properly, because they jump back to their initial position (link to video)
- the initial order of the fields is not in line with the actual fields order in the content list view when first entering the view
- fields can be reordered and stay in their new position
- fields have the correct position when entering the UI tab of the schema settings page
- navigate to:
https://cloud.squidex.io/app/<appId>/schemas/<schemaId>?tab=ui - drag a field to a different position (on the left side)
- release the field handle
- field jumps back to its old position
- click save
- navigate to content list view of the schema, order of fields/columns has changed
- navigate back to schema settings, ui tab
- fields are still shown in wrong order
- [x] Cloud version
- [x] Chrome (desktop, MacOS)
