- [x] Bug report
Most operations on a large content item (~10k lines when viewed in Inspect > Flat Data view) fail with MongoDB error (detailed error attached):
Command update failed: Only servers in a sharded cluster can start a new transaction at the active transaction number.
This sometimes happens when trying to create the content (attached detailed error error-during-create.json) and always happens when trying to change the status (e.g. moving from Draft to Published) (attached detailed error error-during-change-status.json). Restarting the Squidex instance sometimes help.
I am able to operate on large content.
- Create attached schema
schema.json. - Insert
content-small.jsoncontent into the schema. Publish it. See it working. - Insert
content-large.jsoncontent into the schema. It should fail with the error described here. - If large content creation worked, try to publish it. It should fail with the error described here.
You can see these steps done in the attached video reproduction-steps.mp4.
- [x] Self hosted with docker
Version: 7.0.3
- [x] Chrome (desktop)
- This has only started since upgrading to v7. No such errors where observed on v6 (6.8.0).
- New v7 config in our Squidex:
STORE__MONGODB__VALUEREPRESENTATION=Document
CONTENTS__OPTIMIZEFORSELFHOSTING=true
CLUSTERING__WORKER=false
There’s a separate instance with CLUSTERING__WORKER=true. Errors described here occur in the instance with CLUSTERING__WORKER=false.
Errors described here happen even if CONTENTS__OPTIMIZEFORSELFHOSTING=false or when STORE__MONGODB__VALUEREPRESENTATION=String or STORE__MONGODB__VALUEREPRESENTATION=Binary.
- Our MongoDB server is an Atlas M10 cluster (Replica Set - 3 nodes).
- This is really the only thing I could find when Googling “Only servers in a sharded cluster can start a new transaction at the active transaction number.”.
