I am using squidex:5.4.0 docker with the following configuration:
marketing-cms:
image: squidex/squidex:5.4.0
restart: always
environment:
URLS__BASEURL: "https://marketing-cms"
EVENTSTORE__TYPE: MongoDB
EVENTSTORE__MONGODB__CONFIGURATION: mongodb://marketing-cms-datastore
IDENTITY__ADMINEMAIL: "test@test.de"
IDENTITY__ADMINPASSWORD: "xxx"
UI__REDIRECTTOLOGIN: "true"
IDENTITY__adminClientId: "admin"
IDENTITY__adminClientSecret: "xxx"
IDENTITY__googleClient: ""
IDENTITY__googleSecret: ""
IDENTITY__githubClient: ""
IDENTITY__githubSecret: ""
IDENTITY__microsoftClient: ""
IDENTITY__microsoftSecret: ""
depends_on:
- marketing-cms-datastore
volumes:
- ./volumes/marketing-cms:/app/Assets
labels:
traefik.enable: true
traefik.http.routers.marketing-cms.rule: Host(`marketing-cms`)
traefik.http.routers.marketing-cms.tls: true
traefik.http.services.marketing-cms.loadbalancer.server.port: 80
I am using a read-only anonymous client to access my content.
I created some schemas and content and initially, everything ran fine.
But now I am getting sometimes mysterious 404 responses for the same endpoint that sometimes successfully answers my request.
I even can reproduce that when I refresh the Squidex UI in my browser then immediately afterward the request (in Postman) succeeds. But after some time the same request returns 404 again (in Postman).
The Squidex UI seems to work properly and I never get a 404.
Only one thing is strange the cluster overview in the UI gives me a 500 response.
"logLevel": "Information",
"message": "Application started",
"environment": {
"applicationname": "Squidex",
"aspnetcore_urls": "http://\u002B:80",
"aspnet_version": "5.0.0",
"assets:defaultpagesize": "200",
"assets:defaultpagesizegraphql": "20",
"assets:deleterecursive": "True",
"assets:maxresults": "200",
"assets:maxsize": "5242880",
"assetstore:amazons3:accesskey": "\u003CMY_KEY\u003E",
"assetstore:amazons3:bucket": "squidex-test",
"assetstore:amazons3:bucketfolder": "squidex-assets",
"assetstore:amazons3:forcepathstyle": "False",
"assetstore:amazons3:regionname": "eu-central-1",
"assetstore:amazons3:secretkey": "\u003CMY_SECRET\u003E",
"assetstore:amazons3:serviceurl": "",
"assetstore:azureblob:connectionstring": "UseDevelopmentStorage=true",
"assetstore:azureblob:containername": "squidex-assets",
"assetstore:exposesourceurl": "False",
"assetstore:folder:path": "Assets",
"assetstore:ftp:password": "",
"assetstore:ftp:path": "Assets",
"assetstore:ftp:serverhost": "",
"assetstore:ftp:serverport": "21",
"assetstore:ftp:username": "",
"assetstore:googlecloud:bucket": "squidex-assets",
"assetstore:mongodb:bucket": "fs",
"assetstore:mongodb:configuration": "mongodb://localhost",
"assetstore:mongodb:database": "SquidexAssets",
"assetstore:type": "Folder",
"caching:maxsurrogatekeyssize": "0",
"caching:replicated:enable": "True",
"caching:strongetag": "False",
"contentroot": "/app",
"contents:defaultpagesize": "200",
"contents:defaultpagesizegraphql": "20",
"contents:maxresults": "200",
"dotnet_running_in_container": "true",
"dotnet_version": "5.0.0",
"email:notifications:existinguserbody": "Dear User,\r\n\r\n$ASSIGNER_NAME ($ASSIGNER_EMAIL) has invited you to join App $APP_NAME at Squidex Headless CMS.\r\n\r\nLogin or reload the Management UI to see the App.\r\n\r\nThank you very much,\r\nThe Squidex Team\r\n\r\n\u003C\u003CStart now!\u003E\u003E [$UI_URL]",
"email:notifications:existingusersubject": "[Squidex CMS] You have been invited to join App $APP_NAME",
"email:notifications:newuserbody": "Welcome to Squidex\r\nDear User,\r\n\r\n$ASSIGNER_NAME ($ASSIGNER_EMAIL) has invited you to join Project (also called an App) $APP_NAME at Squidex Headless CMS. Login with your Github, Google or Microsoft credentials to create a new user account and start editing content now.\r\n\r\nThank you very much,\r\nThe Squidex Team\r\n\r\n\u003C\u003CStart now!\u003E\u003E [$UI_URL]",
"email:notifications:newusersubject": "You have been invited to join Project $APP_NAME at Squidex CMS",
"email:notifications:usagebody": "Dear User,\r\n\r\nYou you are about to reach your usage limit for App $APP_NAME at Squidex Headless CMS.\r\n\r\nYou have already used $API_CALLS of your monthy limit of $API_CALLS_LIMIT API calls.\r\n\r\nPlease check your clients or upgrade your plan!\r\n\r\n\u003C\u003CGo to Squidex!\u003E\u003E [$UI_URL]",
"email:notifications:usagesubject": "[Squidex CMS] You you are about to reach your usage limit for App $APP_NAME",
"email:smtp:enablessl": "True",
"email:smtp:password": "",
"email:smtp:port": "587",
"email:smtp:sender": "hello@squidex.io",
"email:smtp:server": "",
"email:smtp:username": "",
"eventpublishers:alltorabbitmq:configuration": "amqp://guest:guest@localhost/",
"eventpublishers:alltorabbitmq:enabled": "False",
"eventpublishers:alltorabbitmq:eventsfilter": ".*",
"eventpublishers:alltorabbitmq:exchange": "squidex",
"eventpublishers:alltorabbitmq:type": "RabbitMq",
"eventstore:cosmosdb:configuration": "https://localhost:8081",
"eventstore:cosmosdb:database": "Squidex",
"eventstore:cosmosdb:masterkey": "C2y6yDjf5/R\u002Bob0N8A7Cgv30VRDJIWEHLM\u002B4QDU5DE2nQ9nDuVTqobD4b8mGGyPMbIZnqyMsEcaGQy67XIw/Jw==",
"eventstore:geteventstore:configuration": "ConnectTo=tcp://admin:changeit@localhost:1113; HeartBeatTimeout=500; MaxReconnections=-1",
"eventstore:geteventstore:prefix": "squidex",
"eventstore:geteventstore:projectionhost": "localhost",
"eventstore:mongodb:configuration": "mongodb://marketing-cms-datastore",
"eventstore:mongodb:database": "Squidex",
"eventstore:type": "MongoDB",
"exposedconfiguration:version": "squidex:version",
"fulltext:elastic:configuration": "http://localhost:9200",
"fulltext:elastic:indexname": "squidex",
"fulltext:type": "default",
"healthz:gc:threshold": "4096",
"home": "/root",
"hostname": "aea3ea478ba3",
"identity:adminclientid": "admin",
"identity:adminclientsecret": "xxx",
"identity:adminemail": "test@test.de",
"identity:adminpassword": "xxx",
"identity:adminrecreate": "False",
"identity:allowpasswordauth": "True",
"identity:githubclient": "",
"identity:githubsecret": "",
"identity:googleclient": "",
"identity:googlesecret": "",
"identity:lockautomatically": "False",
"identity:microsoftclient": "",
"identity:microsoftsecret": "",
"identity:microsofttenant": "",
"identity:oidcauthority": "",
"identity:oidcclient": "",
"identity:oidcname": "OIDC",
"identity:oidcscopes:0": "email",
"identity:oidcsecret": "",
"identity:privacyurl": "https://squidex.io/privacy",
"identity:showpii": "True",
"kafka:bootstrapservers": "",
"languages:custom": "",
"logging:colors": "True",
"logging:datadog": "False",
"logging:human": "True",
"logging:level": "Information",
"logging:logprofiler": "False",
"logging:logrequests": "True",
"logging:storeretentationindays": "90",
"mode:isreadonly": "False",
"news:appname": "squidex-website",
"news:clientid": "squidex-website:default",
"news:clientsecret": "QGgqxd7bDHBTEkpC6fj8sbdPWgZrPrPfr3xzb3LKoec=",
"orleans:clustering": "Development",
"orleans:gatewayport": "40000",
"orleans:ipaddress": "",
"orleans:siloport": "11111",
"path": "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"plugins:0": "Squidex.Extensions.dll",
"rebuild:apps": "False",
"rebuild:assetfiles": "False",
"rebuild:assets": "False",
"rebuild:contents": "False",
"rebuild:indexes": "False",
"rebuild:rules": "False",
"rebuild:schemas": "False",
"robots:text": "User-agent: *\nAllow: /api/assets/*",
"rules:executiontimeoutinseconds": "10",
"running_in_container": "true",
"store:mongodb:configuration": "mongodb://marketing-cms-datastore",
"store:mongodb:contentdatabase": "SquidexContent",
"store:mongodb:database": "Squidex",
"store:type": "MongoDb",
"translations:deepl:authkey": "",
"translations:googlecloud:projectid": "",
"twitter:clientid": "QZhb3HQcGCvE6G8yNNP9ksNet",
"twitter:clientsecret": "Pdu9wdN72T33KJRFdFy1w4urBKDRzIyuKpc0OItQC2E616DuZD",
"ui:disablescheduledchanges": "False",
"ui:google:analyticsid": "UA-99989790-2",
"ui:hidedatebuttons": "False",
"ui:hidedatetimemodebutton": "False",
"ui:hidenews": "False",
"ui:hideonboarding": "False",
"ui:map:googlemaps:key": "AIzaSyB_Z8l3nwUxZhMJykiDUJy6bSHXXlwcYMg",
"ui:map:type": "OSM",
"ui:onlyadminscancreateapps": "False",
"ui:redirecttologin": "true",
"ui:referencesdropdownitemcount": "100",
"ui:regexsuggestions:email": "^[a-zA-Z0-9.!#$%\u0026\u2019*\u002B\\/=?^_\u0060{|}~-]\u002B@[a-zA-Z0-9-]\u002B(?:.[a-zA-Z0-9-]\u002B)*$",
"ui:regexsuggestions:phone": "^\\(*\\\u002B*[1-9]{0,3}\\)*-*[1-9]{0,3}[-. /]*\\(*[2-9]\\d{2}\\)*[-. /]*\\d{3}[-. /]*\\d{4} *e*x*t*\\.* *\\d{0,4}$",
"ui:regexsuggestions:slug": "^[a-z0-9]\u002B(\\-[a-z0-9]\u002B)*$",
"ui:regexsuggestions:url": "^(?:http(s)?:\\/\\/)?[\\w.-]\u002B(?:\\.[\\w\\.-]\u002B)\u002B[\\w\\-\\._~:\\/?#%[\\]@!\\$\u0026\u0027\\(\\)\\*\\\u002B,;=.]\u002B$",
"ui:showinfo": "False",
"urls": "http://\u002B:80",
"urls:baseurl": "https://marketing-cms",
"urls:enableforwardheaders": "True",
"urls:enforcehost": "False",
"urls:enforcehttps": "False",
"version": "5.0.0"
"app": {
"name": "Squidex",
"version": "5.4.0.0",
"sessionId": "e716c961-4f9e-4fd8-9165-b075595f48dc"
"timestamp": "2021-02-01T17:49:01Z"
"filters": {
"costs": 0
"elapsedRequestMs": 26,
"app": {
"name": "Squidex",
"web": {
"requestId": "00-400abfb20a0d4d489ed7b5178cec0920-05f138ede3a74444-00",
"requestPath": "/orleans",
"requestMethod": "GET"
"timestamp": "2021-02-01T18:01:21Z"
"logLevel": "Error",
"message": "An unexpected exception has occurred.",
"app": {
"name": "Squidex",
"web": {
"timestamp": "2021-02-01T18:01:21Z",
"exception": {
"type": "System.InvalidOperationException",
"message": "IDX20803: Unable to obtain configuration from: \u0027https://marketing-cms/identity-server/.well-known/openid-configuration\u0027.",
"stackTrace": " at Microsoft.IdentityModel.Protocols.ConfigurationManager\u00601.GetConfigurationAsync(CancellationToken cancel)\n at Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler.HandleChallengeAsyncInternal(AuthenticationProperties properties)\n at Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler.HandleChallengeAsync(AuthenticationProperties properties)\n at Microsoft.AspNetCore.Authentication.AuthenticationHandler\u00601.ChallengeAsync(AuthenticationProperties properties)\n at Microsoft.AspNetCore.Authentication.AuthenticationService.ChallengeAsync(HttpContext context, String scheme, AuthenticationProperties properties)\n at Squidex.Areas.OrleansDashboard.Middlewares.OrleansDashboardAuthenticationMiddleware.InvokeAsync(HttpContext context) in /src/src/Squidex/Areas/OrleansDashboard/Middlewares/OrleansDashboardAuthenticationMiddleware.cs:line 47\n at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.Invoke(HttpContext context)\n at Squidex.Web.Pipeline.LocalCacheMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/LocalCacheMiddleware.cs:line 32\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.\u003C\u003Ec__DisplayClass6_1.\u003C\u003CUseMiddlewareInterface\u003Eb__1\u003Ed.MoveNext()\n--- End of stack trace from previous location ---\n at Microsoft.AspNetCore.Localization.RequestLocalizationMiddleware.Invoke(HttpContext context)\n at Squidex.Web.Pipeline.UsageMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/UsageMiddleware.cs:line 91\n at Squidex.Web.Pipeline.UsageMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/UsageMiddleware.cs:line 91\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.\u003C\u003Ec__DisplayClass6_1.\u003C\u003CUseMiddlewareInterface\u003Eb__1\u003Ed.MoveNext()\n--- End of stack trace from previous location ---\n at Squidex.Web.Pipeline.RequestLogPerformanceMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/RequestLogPerformanceMiddleware.cs:line 61\n at Microsoft.AspNetCore.Builder.UseMiddlewareExtensions.\u003C\u003Ec__DisplayClass6_1.\u003C\u003CUseMiddlewareInterface\u003Eb__1\u003Ed.MoveNext()\n--- End of stack trace from previous location ---\n at Squidex.Web.Pipeline.RequestExceptionMiddleware.InvokeAsync(HttpContext context, RequestDelegate next) in /src/src/Squidex.Web/Pipeline/RequestExceptionMiddleware.cs:line 69"
I am not sure whether the problem is that the client uses “anonymous” access (maybe I can test this afterward).
Any ideas on how to debug this? The logs do not show any errors, except for the Cluster problem ( Regarding this: I can access the identity server at https://marketing-cms/identity-server/.well-known/openid-configuration without problem in the browser).
- Create app, schemas, content, and a read-only API client with anonymous access
- Make a GET request with Postman to access content => 404 (NotFound)
- Refresh the Squidex UI in Chrome Browser and make the same GET request in Postman afterward => 200 (Success)
- Wait some seconds and make the same GET request in Postman => 404 (NotFound)
If you are interested I can send you the mongodb folder (7mb) which can be used to reproduce the problem surely.
- [x] Self hosted with docker
Version: [5.4.0]
- [x] Chrome (desktop)
