- [x] Used code blocks with ``` to format my code examples like JSON or logs properly.
- [x] Performance issue
I checked logs recently a i noticed (I finally set up logging mongo to seq) there are lot of “Slow query” in mongoDb. I am not sure if it is related to any change as I recently updated docker to the last version and i unfortunately cannot check if it is same.
Raw log entry:
"command": {
"$db": "Squidex",
"filter": {
"EventStream": {
"$regularExpression": {
"options": "",
"pattern": "^app-|^app-"
"Timestamp": {
"$gt": {
"$timestamp": {
"i": 1,
"t": 1664745154
"find": "Events2",
"limit": 2147483647,
"lsid": {
"id": {
"$uuid": "982c73ba-cd2d-4216-8f58-831afbb6aa87"
"sort": {
"EventStream": -1,
"Timestamp": 1
"cursorExhausted": true,
"docsExamined": 0,
"durationMillis": 1384,
"fromMultiPlanner": true,
"keysExamined": 154022,
"locks": {
"FeatureCompatibilityVersion": {
"acquireCount": {
"r": 925
"Global": {
"acquireCount": {
"r": 925
"Mutex": {
"acquireCount": {
"r": 1
It’s almost exclusively "^app-|^app-" only other what i found was with '^schema-', '^assetFolder-', '^asset-' but that was just few occasions which may be related to something else (GC?). "^app-|^app-" happen all the time.
No slow query or should be logged is Squidex? Or I can consider it normal as i do not think I notice anything not working.
It is tricky as this is log from mongo so I do not have exact context from squidex.
- [x] Self hosted with docker
Version:7.8.2
as we have currently still lots of these messages in log
