[SOLVED] Localization with a hyphen can't be filtered on
[x] Bug report
[ ] Performance issue
When trying to filter on a language that contains a hyphen e.g nl-BE the OData filter is required to be in an invalid format: $filter=data/Title/nl-BE eq ‘Something’
To be able to filter on these languages.
Create a schema localized in a language with a hyphen in it’s name and try to filter on it
  • [x] Self hosted with version docker
  • [ ] Chrome (desktop)
I noticed the same happens when you create your own property with a hyphen, but I guess I should just change the name in this case.
If you have a property with a hyphen you can just use underscore in your queries.
Fix is in the CI pipeline.
Thank you. The underscore works fine. I’ll wait for the fix for the languages.
It might take a little bit longer because github is not fully operational: https://status.github.com/messages
Hi, the fix has been deployed. You also have to use underscore for languages, so replace de-AT with de_AT.
