- [ X ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [ X ] Bug report
I noticed that when the values of a field are not set for a language which is not set as the master language and has a fallback to a language whose field does have a value, the API is returning a empty value.
In this case, I’m querying for an item in language ‘no’. The result value for field ‘display-name’ is empty
Item Id: 152ebdf0-d319-49fd-969a-1b5a1437f995
However, when I add ‘en’ to the language headers as well, then the result for ‘no’ is properly populated with the fallback value from the ‘en’ language
Is there something we’re missing or has there been updates lately to this?
When requesting the content for a language which doesn’t have a value, the value of the fallback language should be returned.
App Name: IvaGaming
- [ X ] Cloud version
Version: Cloud
- [ ] Chrome (desktop)
- [ X ] Postman / API
N/A
