- Bug report
- Performance issue
Go to “Content”, choose one of the sechemas, click “New draft” button - view is not changed to edit, all schema fields are still disabled
every field should be enabled and can be changed
App Name: Mine
- Self hosted with docker
- Self hosted with IIS
- Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
Attached screenshot - the schema is in draft mode but can’t edit fields:
