Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
Regression (a behavior that stopped working in a new release)
Bug report
Performance issue
Documentation issue or request
When I press ‘,’ button Tag finises independent of my keyboard language layout
Tag should be finished only when symbol ‘,’ entered not ‘,’ button is pressed.
It’s a problem when use non-USA keyboard layout.
I’m using Romanian and Ukranian keyboard layout and on ‘,’ button are set another symbols. But when I try to type it, Tag is ending instead of new symbol.
When i use KEY OR CODE and press ‘б’ symbol (situated on ‘,’ key) I see message in console.
When i use KEY ONLY and press ‘б’ symbol (situated on ‘,’ key) nothing happens.
I think than key only is a correct behavior.
