Hi there
the resizer does not seem to work.
if only one parameter is specified, for example:
?width=300 or ?height=300
if both parameters are given:
?width=300&height=300
Greetings Andreas
Version: 4.1 RC1
Is there something missing because you started your sentences with “if”.
Are you talking about the UI or the API?
Not working
https://cms.webnerds.ch/api/assets/56322aa3-6cdb-4d0b-b9da-49eca72d8e34?width=500
Working
https://cms.webnerds.ch/api/assets/56322aa3-6cdb-4d0b-b9da-49eca72d8e34?width=500&height=300
I usually generate the URL via SquidexClientManager and put the parameters behind it.
Example:
<img src="@SquidexClientManager.GenerateImageUrl(Model.Logo[0])?width=500&height=215" class="logo-default" />
I have pushed a fix, could take a few minutes until the build is done.
