If i try to open image with set format=WEBP as is in docs https://cloud.squidex.io/api/docs#operation/AssetContent_GetAssetContent
For example:
https://cloud.squidex.io/api/assets/test-test-1234/add93813-4ef0-40e8-8019-610955cd6e53?format=WEBP&force=true&width=1100
If i do not set format parameter it seems like it returns same image (same size same content type).
WEBP vs non-set
It seems like it still returns to its original format (jpg). Is it expected? Is there a way to get WEBP format from non webp format?
Convert image to set format.
App Name: test-test-1234
- [X] Self hosted with docker
- [X] Cloud version
Version: last stable
- [X] Chrome (desktop)
