- [x] Bug report
Enabling half width for array nested fields does not shows the fields in half width in the text editor
half width functionalitu should work for array nested fields as well. Similar to how it works for fields at root level
- Create an array field
- Add a nested field of any type and enable half width
- Add another nested field of any type and enable half width on this as well
- Publish the schema and create new content
- the nested array fields take full width in the text editor instead of half width
App Name: myapp1234
- [x] Cloud version
Version: [5.0.0.0] (https://cloud.squidex.io/api/info)
- [x] Chrome (desktop)
