[SOLVED] GraphQL top parameter not respected, cannot fetch more than 20 items
[ x] Regression (a behavior that topped working in a new release)
[ ] Bug report
[ ] Performance issue
With GraphQL Query: {
queryTestContentsWithTotal(top:24) {
total
items {
id
Total returns 24, but there are only 20 items listed
When I specify top:XXXX I expect at most XXXX items returned, and not the default value of 20
Create more than 20 content items in Schema. Query for contents using top: 21 parameter. Notice only 20 content items are returned.
  • [ ] Self hosted with version docker
  • [ x] Cloud version
  • [x] Chrome (desktop)
I also see that the REST API has the same issue: https://cloud.squidex.io/api/content/APP/SCHEMA?$top=24
Thank you, I will fix it today.
Fix is in the Build pipeline.
