I think the general api part on both the master repo and cloud.squidex.io is not working properly due to the updates. There are problems with the output on the Open API side (no messages 200, 201 etc.)
Thx, it is only an OpenApi issue but I will have a look tomorrow
I would appreciate it if you would prioritize this. Because I made some changes that touch API side using master repository. Currently, I cannot update the ClientLibrary and Generated.cs because the API side is not working.
Thank you very much for your interest and understanding.
I have pushed a fix.
