getting an error while adding contributor to the project.
Posted Url : https://localhost:5001/api/apps/deneme/contributors 404 not found.
And UI Bug:
Click Language and ui bug:
Workflow scroll bug:
Thank you.
And UI Bug:
Thank you.
Hi, the workflow thing is not a bug. The contents are designed to have a certain width and the scrollbar is added if this space is not available. But I will check the other issues.
I fixed both issues.
