[SOLVED] $filter=created eq 1988-01-19T12:00:00Z
‘eq’ in ‘$filter=created eq 1988-01-19T12:00:00Z’ doesn’t seem to work this way?
Any idea?
  • [ ] Checked the logs and have provided uploaded a log file and provided a link because I found something suspicious there.
  • [ ] Bug report
  • [ ] Self hosted with docker
  • [ ] Chrome (desktop)
What problem do you see?
It doesn’t work for created/lastModified specifically. However for other userdefined datetime column it works.
For e.g. it works for $filter=data/displayDate/iv ge 2019-09-13T08:00:41Z but not for $filter=created ge/ge/eq 2019-09-13T08:00:41Z. I know there is data.
True, I will have a look asap.
Returns 0 records;
“total”: 0,
“items”: [],
“statuses”: [
“status”: “Archived”,
“color”: “#eb3142”
“status”: “Draft”,
“color”: “#8091a5”
“status”: “Published”,
“color”: “#4bb958”
“_links”: {
“self”: {
“href”: “/api/content/sundarfac1/blog”,
“method”: “GET”
“create”: {
“method”: “POST”
“create/publish”: {
“href”: “/api/content/sundarfac1/blog?publish=true”,
“method”: “POST”
I have solved it and deployed the bugfix to the cloud.
