[SOLVED] Error starting Squidex after pulling latest code from github
  • [ X] Checked the logs and have provided the logs if I found something suspicious there
  • [X ] Bug report
After pulling down the latest code from the “master” branch… I did a dotnet restore and then…
Calling “dotnet run” from command line, startup fails
It would work… sitting, waiting on port 5000
  • [ ] Self hosted with docker
  • [X ] Self hosted with other version
Latest code on “master” branch
  • [ ] Chrome (desktop)
Error seen:
“logLevel”: “Fatal”,
“message”: “An error occurred starting the application”,
“eventId”: {
“id”: 9
“exception”: {
“type”: “System.AggregateException”,
“message”: “One or more errors occurred. (Element ‘Created’ does not match any field or property of class Squidex.Domain.Apps.Entities.MongoDb.Assets.MongoAssetEntity.)”,
“stackTrace”: " at Microsoft.AspNetCore.Hosting.Internal.HostedServiceExecutor.ExecuteAsync(Func`2 callback)\r\n at Microsoft.AspNetCore.Hosting.IHosting environment: Development
nternal.HostedServiceExecutor.StartAsync(CancellationToken token)"
“app”: {
“name”: “Squidex”,
“version”: “1.0.0.0”,
“sessionId”: “e19f4e45-2e1e-46d9-988e-36fbb5c23031”
“timestamp”: “2019-08-20T22:51:59Z”,
“category”: “MContent root path: C:\Git\squidex\src\Squidex
icrosoft.AspNetCore.Hosting.Internal.HostedServiceExecutor”
Can you upload your full logs and send me the link?
Can you also check the Migration Collection in MongoDB? If it shows version 18, change it to 17 and restart it again.
Just checking Sebastian, is there an upgrade process that I need to do when running the 3.x codebase ?
it should upgrade automatically, but it has not done it. Therefore I am confused.
How would I go about doing this ?
You can use a mongo client like studio3t
Currently, the version is sitting at 14
Can you make a backup of Squidex database and send it to me?
The dump of the Squidex database is here:
https://drive.google.com/open?id=1l6iL2YsqyRegrdw95HybhZjNKct-Ql28
And here is the log file
https://drive.google.com/open?id=1rVfTolTRtFqRYaF2Ll2iL7uPkYS1lQ7Y
Thank you. This was very helpful indeed. If you have time try the latest dev version please. I have pushed a fix.
Many thanks Sebastian, we are back up and running.
I did notice however that we now have an endless log of:
“logLevel”: “Trace”,
“action”: “HandleEvent”,
“actionId”: “e24d0444-5d8e-47eb-b29b-c3cb7f163e67”,
“status”: “Completed”,
“eventId”: “e24d0444-5d8e-47eb-b29b-c3cb7f163e67”,
“eventType”: “ContentUpdated”,
“eventConsumer”: “TextIndexer”,
“elapsedMs”: 2,
“app”: {
“name”: “Squidex”,
“sessionId”: “c7fa1f7f-aeef-4c1e-a76b-3aef1ca30cfd”
“timestamp”: “2019-08-22T15:46:05Z”
“logLevel”: “Information”,
“actionId”: “bc9bfec6-cf5d-4641-ad1d-d6dc09bf6106”,
“status”: “Started”,
“eventId”: “bc9bfec6-cf5d-4641-ad1d-d6dc09bf6106”,
“app”: {
“name”: “Squidex”,
They will stop after a while. They are updating the full text index in the background. You will just see them so often now, because the full text index has not been populated yet.
Awesome work Sebastian… many thanks for the help.
