[SOLVED] Error on upload asset
[X] Bug report
[ ] Performance issue
When I try to upload new asset (both drag and drop or by clicking the select file button I get the error message:
Failed to upload asset. Please reload.
However, the asset does actually upload correctly and is available after the error message has shown. The only issue is that the error message is incorrectly displayed.
Upload should work without error message.
I’ve tried it with PNG and SVG filetypes.
  • [ ] Self hosted with docker
  • [X] Cloud version
  • [X] Chrome (desktop)
Thank you, it seems to be an issue with google cloud storage. Perhaps a temporary error only, because I have never seen it before and the error message is unclear and confusing. I will investigate it tomorrow, it is already very late here in Germany.
No problem, the upload works anyway so not an issue for me at all.
Thanks
I posted on stackoverflow: https://stackoverflow.com/questions/53300767/copy-objects-in-google-cloud-objects-started-to-fail … Have no idea what the problem is.
Google could reproduce the issue, I think the problem is not on my side and it stopped to work suddenly.
Google has confirmed the bug in the client library and fixed it.
The fix has been deployed.
