Schemas > Select any schema > JSON
Modify any “pattern” field and hit “Synchronize”.
Does not update the schema with the following message:
“Nothing has been changed.”
Which version are you using? Please use the template for new issues.
Thanks, I was able to reproduce and fix that.
