[SOLVED] Disabling fields from rich text editor
  • [+] Bug report
I have the richtext editor field disabled in a specific status or in the field settings. Although the field is disabled, it is not grayed out, the buttons for example for changing heading h1 h2 etc. work.
The richtext editor field should be grayed out and there should be no option to use buttons in the editor.
Set the field with richtext editor to disabled in settings
  • [ +] Self hosted with docker
  • [+ ] Cloud version
  • [+ ] Firefox
Hi.
I have fixed the problem in the latest dev build
This topic was automatically closed after 31 hours. New replies are no longer allowed.
