Now, im linking this to a cdn and the casing does matter if i only want to use the slug in for my products. Take this one as an example
https://mysquidex.com/api/assets/brand-guide/4aced40e-0845-434f-8c08-71bc366a9aa6/plejd_product_sheet_LED-75_PL.pdf?version=1 works
https://mysquidex.com/api/assets/brand-guide/plejd_product_sheet_LED-75_PL.pdf?version=1 works
https://mysquidex.com/api/assets/brand-guide/plejd_product_sheet_led-75_pl.pdf?version=1 does not work
Now in my cdn
https://brand-cdn.plejd.com/plejd_product_sheet_LED-75_PL.pdf works
https://brand-cdn.plejd.com/plejd_product_sheet_led-75_PL.pdf does not work.
How ever, I discovered the issue is not really a discrepancy in environments, it’s the “generate slug” button that works different when you press it as a user or if you run it via script.
example (this file does not exist btw)
if I upload a file with the name “this_IS_MY-file.pdf” the url will sometimes (not sure why it’s just sometimes) become something like:
https://mysquidex.com/api/assets/brand-guide/4aced40e-0845-434f-8c08-71bc366a9aa6/this-is-my-file.pdf?version=1 (yes with “-” and lowecase)
If i press “generate slug” it will pickup the “_” so now the url is
https://mysquidex.com/api/assets/brand-guide/4aced40e-0845-434f-8c08-71bc366a9aa6/this_is_my-file.pdf?version=1 how ever, the casing will still be lowercase but if i run it with my script that runs “generate slug” for all assets it will also pickup the casing
https://mysquidex.com/api/assets/brand-guide/4aced40e-0845-434f-8c08-71bc366a9aa6/this_IS_MY-file.pdf?version=1
This is my script for generating slugs on all assets (no weirdness here?)
import 'dotenv/config';
import { getAccessToken, getAllSquidexAssets } from './helper.mjs';
const SQUIDEX_APP_NAME = process.env.SQUIDEX_APP_NAME;
const SQUIDEX_URL = process.env.SQUIDEX_URL;
* Updates the slug for a given asset.
* This function replicates the logic found in `uploadFiles.mjs`.
* @param {string} assetId The ID of the asset to update.
* @param {string} newSlug The new slug to set for the asset.
* @param {string} token The authorization token for the Squidex API.
async function updateAssetSlug(assetId, newSlug, token) {
const url = new URL(`/api/apps/${SQUIDEX_APP_NAME}/assets/${assetId}`, SQUIDEX_URL);
const body = { slug: newSlug };
try {
const response = await fetch(url, {
method: 'PUT',
body: JSON.stringify(body),
headers: {
'Content-Type': 'application/json',
Authorization: `Bearer ${token}`,
if (response.ok) {
console.log(`Successfully updated slug for asset ID ${assetId} to: ${newSlug}`);
} else {
console.error(`Error updating slug for asset ID ${assetId}: ${response.status} ${await response.text()}`);
} catch (error) {
console.error(`Error updating slug for asset ID ${assetId}:`, error);
async function main() {
console.log('Starting script to generate slugs for all Squidex assets...');
const token = await getAccessToken();
if (!token) {
console.error('Failed to get access token. Exiting.');
return;
console.log('Fetching all assets from Squidex...');
const allAssets = await getAllSquidexAssets();
console.log(`Found ${allAssets.length} assets to process.`);
let updatedCount = 0;
for (const asset of allAssets) {
// We only care about assets (files), not folders.
if (asset.type === 'Folder' || !asset.fileName) {
continue;
if (asset.slug !== asset.fileName) {
console.log(`Asset ${asset.id} ('${asset.fileName}') needs slug update. Current slug: '${asset.slug}'.`);
await updateAssetSlug(asset.id, asset.fileName, token);
updatedCount++;
console.log('--------------------');
console.log('Script finished.');
if (updatedCount > 0) {
console.log(`Updated slugs for ${updatedCount} assets.`);
} else {
console.log('All asset slugs were already up to date.');
main().catch(console.error);
I also made a screen recording, it’s a bit blurry but think it should work anyway. What it describes
- Upload a file with uppercase and _ in the name
- url becomes all lowercase and -
- generate slug will pick up - or _ but not casing
- delete the file and upload it again
- Run script (the one above) to genereate slug
- Show that this does pick up the casing
- Bug?
