[X] Bug report
[ ] Performance issue
I accidentally created a field in my schema. When I try to delete I’m prompted to confirm field deletion (Do you really want to delete the field?), then I get the error message:
Failed to make the request
Field should be deleted after I click yes on Do you really want to delete the field?
Create a field, then try to delete it. I can give you details for my schema if necessary.
- [X] Cloud version
- [X] Chrome (desktop)
