Hello,
This may well be deliberate and so not a bug, it is also not too important for us as we can use scripts to enforce the correct data is retained. Came across this issue when a field that we programmatically populate with scripts was accidentally emptied by a user causing our data to be in an invalid state.
- [x] Bug report
Fields that are disabled in the UI can have their values changed by users by using the Compare functionality.
Fields that are disabled in the UI should not be able to have their values changed by users when using the Compare functionality.
- Create a schema with a field (have confirmed it happens with String, Boolean, Number and DateTime)
- Publish it
- Create a piece of content for the schema
- Update that content so that you have multiple versions
- Amend schema to disable the field
- View the content again
- you can no longer update the field
- Click ‘Compare’ on the initial version
- Click the back arrow button next to the field
- Click ‘Save’
- The disabled field’s content has been updated
- [x] Self hosted with docker
Version: 377fe120d74085bac86607674b244855cab0215b (More stories (#873))
- [x] Chrome (desktop)
Mitigation for our scenario is to overwrite new empty value with the old populated value:
if (ctx.oldData.DisabledField.iv != null && ctx.data.DisabledField.iv == null) {
ctx.data.DisabledField.iv = ctx.oldData.DisabledField.iv
replace();
