[SOLVED] CLI sync in deletes content fields that has components fields
Seems that dotnet sq sync in deletes all contents field values of type “Components”.
I expect I can do a dotnet sq sync out and then a dotnet sq sync in again.
In real world I hope to do sync out, push to git, pull on other machine and then sync in.
  1. Create schema “test-component” with a single “text” field named “title”:
      "previewUrls": {},
      "properties": {
        "validateOnPublish": false
      "scripts": {},
      "isPublished": true,
      "fieldRules": [],
      "fieldsInLists": [],
      "fieldsInReferences": [],
      "fields": [
          "name": "title",
          "properties": {
            "isRequired": false,
            "isRequiredOnPublish": false,
            "isHalfWidth": false,
            "fieldType": "String",
            "createEnum": false,
            "editor": "Input",
            "inlineEditable": false,
            "isEmbeddable": false,
            "isUnique": false,
            "contentType": "Unspecified"
          "isLocked": false,
          "isHidden": false,
          "isDisabled": false,
          "partitioning": "invariant"
      "type": "Component"
  2. Create schema “test-content” with a single “components” field named “myTestComponents”:
      "previewUrls": {},
      "properties": {
      "scripts": {},
      "fieldRules": [],
      "fields": [
          "name": "myTestComponents",
          "properties": {
            "fieldType": "Components",
            "calculatedDefaultValue": "EmptyArray",
            "minItems": 0,
            "maxItems": 10,
            "schemaIds": ["8e8771e1-135c-468b-b3d4-d7acc934b2b2"]
          "isLocked": false,
          "isHidden": false,
      "type": "Default"
  3. Create a “test-content” item and add 3 components with the title “a”, “b”, “c” in the “myTestComponents” field.
  4. dotnet sq sync out --app cli-test .\cli-sync-issue\data
  5. files on disk looks fine:
      "$schema": "./../__json/contents.json",
      "contents": [
          "schema": "test-content",
          "data": {
            "myTestComponents": {
              "iv": [
                  "schemaId": "test-component",
                  "title": "a",
                  "schemaName": "test-component"
                  "title": "b",
                  "title": "c",
          "id": "62bf8283-0831-4ada-be6a-0332b5aec46e",
          "status": "Published"
      "sourceApp": "cli-test",
      "sourceUrl": "https://cloud.squidex.io/"
  6. dotnet sq sync in --app cli-test .\cli-sync-issue\data:
  7. output from cli:
    * STEP 4 of 7: Importing Contents started
    Upserting #0/0...                       succeeded.
    * STEP 4 of 7: Importing Contents completed
  8. the “myTestComponents” field is now empty :frowning: …
      "createdBy": "subject:672e1301580f3c300b8cd4a2",
      "lastModifiedBy": "client:cli-test:default",
      "data": {
          "iv": []
Version: 7.15.0
Others: no
Thanks for the detailed explanation. I have pushed a fix. The problem was that the CLI converted schema ID to schema names but never back to schema IDs.
This topic was automatically closed after 16 hours. New replies are no longer allowed.
