- [x] Bug report
CLI do not work with untrusted SSL with set parameter -i
I have suspicion that Squidex.ClientLibrary.Configuration.Authenticator do not respect this parameter and even if HttpClient which are uses to access squidex API do.
--ignore-self-signed should work.
- [x] Self hosted with docker
Version: 5.6.0
Error
Executing the following steps
* STEP 0 of 6: Assets
* STEP 1 of 6: Schemas
* STEP 2 of 6: App
* STEP 3 of 6: contents
* STEP 4 of 6: Rules
* STEP 5 of 6: Workflow
* STEP 0 of 6: Exporting Assets started
ERROR: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Boolean async, Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken)
at Squidex.ClientLibrary.Configuration.Authenticator.GetBearerTokenAsync()
at Squidex.ClientLibrary.Configuration.CachingAuthenticator.GetBearerTokenAsync()
at Squidex.ClientLibrary.Utils.AuthenticatingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at Squidex.ClientLibrary.Management.AssetsClient.GetAssetsAsync(String app, Nullable`1 top, Nullable`1 skip, String orderby, String filter, String parentId, String idsQuery, String qQuery, CancellationToken cancellationToken)
at Squidex.ClientLibrary.Management.AssetsClient.GetAllAsync(String app, Func`2 callback, Int32 batchSize, CancellationToken cancellationToken)
at Squidex.CLI.Commands.Implementation.Sync.Assets.AssetsSynchronizer.ExportAsync(DirectoryInfo directoryInfo, JsonHelper jsonHelper, SyncOptions options, ISession session)
at Squidex.CLI.Commands.Implementation.Sync.Synchronizer.<>c__DisplayClass4_0.<<ExportAsync>b__0>d.MoveNext()
--- End of stack trace from previous location ---
at Squidex.CLI.Commands.Implementation.Sync.Extensions.Foreach[T](IEnumerable`1 source, Func`3 action)
at Squidex.CLI.Commands.Implementation.Sync.Synchronizer.ExportAsync(String path, SyncOptions options, ISession session)
at Squidex.CLI.Commands.App.Sync.Out(OutArguments arguments)
at CommandDotNet.Execution.InvocationResultExtensions.GetResultCodeAsync(Object value)
at CommandDotNet.AppRunner.HandleException(Exception ex, IConsole console, CommandContext commandContext)
at CommandDotNet.AppRunner.Run(String[] args)
at Squidex.CLI.Program.Main(String[] args)
