In the latest master, I had to update this plugin to v2.2.1 in order to build the frontend app.
Thanks, it works for me and on the build server.
for me it was a problem when running ./build.sh locally. I think it may be a resource limitation issue, and thus it may have only been a problem on my machine.
I’m using a 2018 macbook pro with 16gb ram. Currently running docker swarm and about 4 instanced of WebStorm. It may have worked if I shut some of those things down first. heh.
But we can just update it…PR is welcome.
