[SOLVED] Backups failing after deleting and re-adding contributor
  • [X] Regression OR
  • [X] Bug report
After I have deleted and re-added a contributor (she could not access the app before), I can not create backups anymore. This also caused a problem where I could not fetch any data, but I have no logs of that.
I only suspect the deleting and re-adding a contributor is the cause of this, because of the timing.
  • [ ] Self hosted with docker
  • [X] Cloud version
  • [X] Chrome (desktop)
Thank you, I think these errors are related. What is your app name?
The app name is ‘way-identity’
It was not related but should be solved.
